MUSIC SOFTWARE FOR EVERYONE
Pro Tools | First
Start creating with free music software for students, musicians, and podcasters
Pro Tools
Get the industry standard audio-production software for songwriters, musicians, producers, and engineers
Pro Tools | Ultimate
Take on demanding professional music and audio post productions
Or click here to purchase from a reseller
Pro Tools is always getting better with new features and improvements. And with your active plan, you get them as soon as we release them. See what's new in Pro Tools 2020.
Bring focus to your session with Folder TracksNEW!
Take command of large sessions by organizing tracks into collapsible folders, enabling you to work more creatively and productively. Without the distraction of seeing numerous tracks on screen. Arrange, consolidate, and route tracks with drag-and-drop ease. And group folders in folders and color-code them for even easier navigation.
Learn about Folder Tracks for music >
Learn about Folder Tracks for audio post >
Folder-Tracks-Temp-Image
EXPRESS YOURSELF
MUSIC CREATION
When inspiration strikes, nothing empowers your creativity like Pro Tools. That’s why top artists, musicians, and audio professionals choose it for everything they do.
The ultimate way to record and create
Thousands of instrument sounds. Seamless punch and loop recording. Automated playlist tracking. All in pristine 24-bit/192kHz audio quality. With Pro Tools, you can make music with up to 768 audio and 1,024 MIDI tracks and use hundreds of plugins to create your sound. All you need is your imagination.
Male keyboardist recording a performance in Pro Tools music software
Compose with MIDI and notation
Nudge notes. Layer sounds. Switch instruments. Transpose parts. The flexible MIDI Editor makes it easy to create and perfect parts. You can even capture MIDI performances and improvisations retroactively. Or view MIDI as music notation in the Sibelius-style Score Editor.
Build up productions on the fly
With Track Presets, you can quickly save, catalog, and recall your favorite effects chains, instrument sounds, vocal processing, and other track settings. It eliminates tedious tinkering, so you can spend more time creating.
Jumpstart your sound with loops, samples, and VIs
Create the parts you need with a wide variety of virtual instrument sounds at your fingertips. Pro Tools music software comes with over 5 GB of high-quality sounds, so you can find the perfect beat, orchestral hit, or piano tone. Plus, you can browse and experiment with loops, samples, and sound effects in context with your tracks.
Get industry-leading audio editing
Pro Tools is renowned for its powerful editing toolset, enabling you to manipulate and perfect nearly every aspect of your audio and MIDI tracks. From trimming clips and reshaping sounds with a single click, to comping together a flawless performance, you can optimize any track with precision.
Male keyboardist editing an audio clip in Pro Tools music software
Edit intelligently with the Smart Tool
Perform multiple types of edits quickly and precisely with a single tool. The Smart Tool provides instant access to every editing tool, changing functions based on your cursor position, eliminating manual tool switching.
Fix timing and pitch with Elastic Audio
Easily tighten up and perfect performances without impacting your original sound. With Elastic Time, you can switch the entire session tempo, change a track’s timing to sit “in the pocket,” or beat-match audio for remixing—without affecting the pitch. Plus, make bad notes sound pitch-perfect or completely warp a track’s tuning to create something unique with Elastic Pitch.
Comp together a perfect performance
Easily comp together multiple takes of a recording to create a single flawless performance. Select portions of a performance and easily cycle through alternative takes. Or, use the Target Playlist to select the best performances from multiple playlists in Waveform view. It’s a great way to explore different improvisations to hear what works best.
Bring your mix to life
From professional-quality plugins and advanced metering, to the best mixing automation in the industry, you have the award-winning sounds and control you need to explore your creativity and deliver your best mix with ease.
Male mixer using Avid S3 and Dock to mix a session in Pro Tools music software
Automate anything
Automate volumes, pans, plugin settings, and more to create balanced mixes quickly. Isolate instruments. Punch up sounds. Create and alter effects. Add movement. Then, change up dynamics and intensity to bring everything together. It’s the easiest, most creative way to handle big complex mixes, without requiring manual performance.
Mix creatively and fluidly during playbackNEW!
With non-stop production, you can stay in your creative groove. Create and delete tracks, add and change plugins, switch presets, adjust loop points and more as your music plays. Freely experiment with 115 different plugins, including emulations of classic hardware EQs, dynamics, and reverb units, without interruption.
Freeze tracks to optimize playback
Mix plugin-heavy sessions with ease. Track Freeze lets you temporarily render all plugin processing on a track with a click of a button to free up CPU power, providing smoother playback for writing and editing automation. It also enables cloud collaborators to hear your mix the way you intend it, without the same plugins. You can then unfreeze tracks to make changes.
Create infinitely with UVI Falcon 2
UVI Falcon 2 is an incredible virtual instrument that makes it easy to create real world and out-of-this-world sounds. Included with Pro Tools at no extra charge.
UVI Falcon is an incredible virtual instrument that makes it easy to create real world and not-of-this-world sounds. Included with Pro Tools at no extra charge.
Create fresh sounds fast
UVI Falcon 2 comes with an expansive, curated sound pack that makes it easy to jump right in and start sculpting sounds immediately. Simply drag and drop samples and effects into UVI Falcon 2 to layer parts and build up sounds, quickly and effortlessly.
See it in action >
UVI Falcon interface showing seven virtual stompbox effects in a computer display
Explore, experiment, and go deep
Create unique sounds with deep control over every aspect of your patches. With 15 oscillators, 80+ effects, and all the sample and synthesis modulation, mixing, and scripting capabilities you could ever want, your sonic possibilities are endless.
UVI Falcon interface showing the Spectral Decay, Wavetable synthesis, Keyboard, and other instrument panels in a computer display
Spark ideas with tons of patches
UVI Falcon 2 includes Factory Sounds, a versatile and extremely high-quality collection of 1,000 patches. Explore your creative possibilities—from classic synths, percussion, and physical modeling, to sample-driven multi-granular soundscapes and multi-oscillator hybrids.
UVI Falcon Factory Sounds interface showing Auto Pan and Tremolo controls for one of 1,000 patches
Get inspired with 2.6 GB of top-quality samples
UVI Falcon 2 and UVI Workstation come with Plugsound Avid Edition, a great-sounding sample library loaded with high-quality keyboard sounds, synthesized sounds, loops, drums, percussion, fretted instruments, and more to help get you started.
Massive power, infinite possibilities
  • Generate and layer together sounds with 15 sample-based and synthesis oscillators optimized for efficient performance
  • Shape sounds with over 80 high-quality effects at your fingertips—from EQs and dynamics, to delays, reverbs, filters, distortion, and more
  • Slice, stretch, silence, shift, and scrub samples with the full-fledged sample editor
  • Produce multichannel, multidimensional sounds in up to 10.2 surround
Three laptop computers in an angled row, showing different UVI Falcon interfaces on their displays
Work with a wide variety of audio loops, samples, files, and instruments, including Soundbanks (.ufs), AIFF, FLAC, MP3, MP4, REX1, REX2, SDII, WAV, SFZ, SND, CAF, and EXS
  • Save your own presets for nearly any module, so you can easily recall ideas for future use
  • Add motion with eight modulation generators that can be used to affect almost anything in the UVI Falcon 2 environment
  • Create your own event processors and skinned instruments from scratch using scripting, or create fully customized macro-driven interfaces
  • Expand your sonic palette with a wide variety of UVI instruments and sounds available from Avid
Collage of three UVI Workstation music software interfaces showing the Meteor sound effect interface in the foreground
GOT PRO TOOLS | FIRST?
Play and tweak sounds with UVI Workstation
UVI Workstation 3 is included for free, providing a powerful sample player and multitimbral instrument to create unique sounds. Play audio content, layer and manipulate parts, and employ an army of effects that’ll make your projects stand out.
Get the details
Start creating now
UVI Falcon 2 and Plugsound Avid Edition are included with Pro Tools and Pro Tools | Ultimate subscriptions and 1-Year Software Updates + Support Plans at no additional cost (a $498 USD value!). UVI Workstation 3 is included for free with Pro Tools | First.
Table showing what UVI music software and sounds are included in Pro Tools | First, Pro Tools, and Pro Tools | Ultimate
Collage of over 20 music software plugin interfaces overlaid on top of the Pro Tools interface in a computer display
Fuel your creativity with pro plugins
115 plugins
Pro Tools
115 plugins NEW!
Pro Tools | First
23 plugins
Classic compressors and EQs. Groundbreaking virtual instruments. Legendary stompboxes. Powerful reverbs. The world’s greatest guitar amps, and much more—all at your fingertips. Get access to an entire studio full of gear with the Avid Complete Plugin Bundle and HEAT now included with all Pro Tools subscriptions.
See what's included  >
Stream and sell your music worldwide
Get your music on Apple Music, Spotify, Pandora, TIDAL, Deezer, TikTok, Amazon Music, iHeartRadio, and many more of the most popular streaming outlets around the world. AvidPlay makes music distribution easy and accessible to all, enabling you to grow your fanbase and keep 100% of your rights and earnings. It’s the easiest way to take control of your career and get discovered.
See options >
AvidPlay Branding and Logo
AVID CLOUD COLLABORATION
Work with anyone, anywhere
Imagine being able to collaborate on a project with bandmates, another artist, songwriter, or producer without anyone leaving their house. With Avid Cloud Collaboration, endless creative possibilities and opportunities await. All you need is Pro Tools audio-production software and an Internet connection.
Discover Cloud Collaboration >
Teal Avid Link logo, representing the Avid creative community for finding, connecting, and collaborating with others
Avid Link interface displayed on a laptop and smartphone for music collaboration
AVID LINK
Connect. Collaborate. Get discovered.
With Avid Link in the Pro Tools interface, you can find and connect with a community of music creators and audio professionals to collaborate and expand your creative opportunities. Plus, get your music heard on Apple Music, Spotify, Pandora, and dozens of other major streaming outlets with AvidPlay.
Discover Avid Link >
MOVE AUDIENCES WITH SOUND
AUDIO POST PRODUCTION
Power your sound with the tools that power the industry. Pro Tools redefines what’s sonically possible in film and television.
Create sound for picture
Capture, design, and build up rich sonic elements and ambience that bring life to moving pictures. With up to 768 voices/audio tracks and 64 HD/UHD video tracks at your disposal, you can create larger-than-life soundtracks with impeccable clarity across all dialogue, overdubs, sound design, music, and effects.
Female editing waveforms with a control surface on the desk and audio production software on her computer display
Edit with surgical precisionNEW!
Work directly with 4K/UHD video, H.264 media, and higher frame rates, enabling you to place and edit sound to picture with greater precision and accuracy. From trimming clips and nudging video frames, to adjusting gain levels and working with 3D audio, Pro Tools makes it fast and easy to tweak and sync sounds to picture.
Collaborate with video teams
Pro Tools makes it easy to import and conform sequences from video editorial for audio post production. It supports 4K/UHD and other video formats natively, enabling you to start working your audio magic without editors needing to transcode video first. You can also quickly exchange mixes between audio and video teams as AAF files.
PRO TOOLS | ULTIMATE
Apply real-time effects to clips
With Clip Effects, you can apply real-time EQ and dynamics to a single audio clip or clip group, enabling multiple clips to have different effects and settings without affecting the rest of the track. It’s ideal for fine-tuning dialogue and voiceovers with variance between clips. Not only does it save you time, it provides better session efficiency.
Mix and deliver any size audio production
Get the mixing power and hands-on control you need to handle the most complex Dolby Atmos and Ambisonics productions. Automate anything—levels, plugins, pans, and more—and Pro Tools will handle the multitude of element adjustments, dynamics, and complex movement tasks for you. So you can focus on creating and delivering your best mix.
Male sitting in front of a large Avid S6 control surface controlling pan positions while viewing video and the audio production software on two displays
Manage large sessions with ease
Mix soundtracks comprised of hundreds of tracks and thousands of clips efficiently with groups. Create a Mix Group to make adjustments to multiple tracks simultaneously. Use VCA masters to adjust overall group levels while maintaining individual track automation. When using a control surface, you can spill VCA groups across your controls to make quick tweaks to individual tracks.
Mix for Netflix with confidenceNEW!
Pro Tools | Ultimate is now part of the Netflix Post Technology Alliance. We’ve worked closely with Netflix to ensure that Pro Tools solutions support Netflix’s technical and workflow requirements today, and into the future. That means you can deliver Netflix-ready mixes quickly, easily, and confidently.
Deliver multiple mixes in a single fileNEW!
Deliver mixes between audio post-production teams and organizations easily, with the ability to bounce multiple Pro Tools stems into a single WAV file. Recipients can then open the stems in separate Pro Tools tracks on file import, preserving the original mixes.
Experience the most powerful immersive audio mixing solution
Together, Pro Tools software, hardware, and Avid control surfaces are the most widely used solution for mixing immersive audio in Hollywood. Whether you’re mixing Dolby Atmos or other 3D audio for film or TV, working in a large mixing stage or a small editing suite, Pro Tools provides the performance and flexibility to meet your needs.
Learn more about delivering Dolby Atmos >
Back of female editing Dolby Atmos session in a smaller audio post suite using Avid S6 and Pro Tools audio production software
PRO TOOLS| ULTIMATE
Mix Dolby Atmos productions
Get the most efficient Dolby Atmos mixing workflows in the industry. Work natively with Atmos 7.1.2 audio stems and object panning. Mix faster while preserving audio fidelity with advanced automation and ADM BWAV support. And get deep Avid control surface integration to accelerate the entire mixing process with hands-on precision.
PRO TOOLS| ULTIMATE
Simplify Dolby Atmos “in the box” mixing
With the latest Dolby Atmos Production Suite and enhanced Core Audio support for Dolby Audio Bridge, you can now send 130 channels from Pro Tools (up from 32) to the Dolby Atmos Renderer. Streamline your mixing and monitoring workflow with a solution that enables you to pre-mix Dolby Atmos projects in any room.
PRO TOOLS| ULTIMATE
Edit and mix VR audio
Create immersive full-sphere surround sound mixes for virtual reality productions—from start to finish. Easily edit and mix audio in a 3D space with support for first-, second-, and third-order Ambisonics formats across your Pro Tools tracks and busses. Then output and deliver content to the required format for playback.
PRO TOOLS | ULTIMATE VOICE PACKS
Expand your voice count
Create bigger mixes with up to 768 voices/audio tracks—without requiring HDX hardware. Add up to three Voice Packs (128 extra voices per pack) to maximize the total number of available voices in Pro Tools | Ultimate software or Pro Tools | HD Native.
Buy now >
Take a test drive >
POWER YOUR PERFORMANCE
SURFACES + HARDWARE
Pro Tools is more than just software. It’s an ecosystem of tightly integrated software, hardware, and control surfaces that work together to accelerate your workflow.
Get hands-on control of your mix
Avid Dock control surface with transport controls, jog wheel, and fader integrated with the free Avid Control app on a tablet
Avid Dock
Avid Dock
Speed up editing and mixing tasks with a full transport, focus fader, jog wheel, and touch control in an ultra-portable surface. Working in concert with the free Avid Control app, Avid Dock provides the access and tactile precision you need to complete projects quickly.
Avid S1 8-fader slimline control surface integrated with the free Avid Control app on a tablet
Avid S1
Avid S1
Mix with the speed and visual feedback of Avid's high-end consoles in a slimline surface. Avid S1 works together with the free Avid Control app on your tablet, providing 8 faders and Avid S6-style metering and processing views to create great-sounding mixes fast.
Avid S3 16-fader compact control surface with built-in 4-input, 6-output audio interface
Avid S3
Avid S3
Get a streamlined yet versatile mixing system for music and audio post. Based on the award-winning Avid S6 control surface, Avid S3 delivers intelligent control over every aspect of Pro Tools and other DAWs, all in a more portable and affordable 16-fader surface.
Avid S4 semi-modular control surface showing 16 faders and two Display Modules in a 3-foot base
Avid S4
Avid S4
Get world-class mixing for smaller studios for budget-conscious pros and smaller facilities. Avid S4 boosts your mixing efficiency with the same touchscreen and Dolby Atmos workflows in a semi-modular design that provides intelligent DAW control.
Flagship Avid S6 large-format, fully modular control surface showing a custom configuration with 48 faders, nine Knob Modules, and six Display Modules
Avid S6
Avid S6
Experience the most intuitive, immersive mixing workflows for modern sound engineers. Avid S6 provides superior ergonomics, intelligent studio control, and the most efficient Dolby Atmos workflows in a fully customizable surface, enabling you to create the best sounding mixes possible—faster.
Artist Mix 8-fader compact control surface
Artist Mix
Artist Mix
Mix projects with greater speed than using a mouse. The 8-fader Artist Mix provides precision control and fast access to a variety of software functions right from the surface. All in a compact footprint that fits perfectly between your keyboard and display.
AVID CONTROL
Get wireless control of your mix
Take control of Pro Tools and more with a free app for iOS, iPadOS, and Android devices. Record and mix faster and easier than working with a mouse and keyboard alone.
Discover Avid Control >
Avid Control Free App 2
HDX Systems
PRO TOOLS | HDX SYSTEMS
Power to push limits
In recording studios and on soundstages, Pro Tools | HDX Systems make the world’s biggest productions possible. Engineered for the highest performance, customization, and expansion. And featuring software, DSP acceleration, and hardware I/O perfectly joined together as one system. They enable music and audio post professionals to deliver their most demanding work. Without constraint.
Discover HDX Systems >
Extend your workflow
Expand your creative opportunities with solutions to extend your Pro Tools capabilities, integration, and workflow.
Enable multi-system sync, extended video workflow capabilities, and collaboration in the studio and beyond.
Avid NEXIS | PRO
Get professional-class shared storage for independent pros and small workgroups.
Discover Avid NEXIS | PRO >
Avid NEXIS | PRO storage engine hardware front panel with purple Avid logo
MediaCentral
Accelerate your media workflow with a unified platform that enables teams to collaborate anywhere.
Discover MediaCentral >
MediaCentral platform software interface on computer display showing image thumbnails of rock climbing in the media browser
Pro Tools | Video Satellite
Bring high-quality video into your audio production workflow.
Discover Pro Tools | Video Satellite >
Pro Tools | Video Satellite interface on computer display showing a Pro Tools surround mix synced with a Media Composer video sequence
Pro Tools | Satellite Link
Simplify multi-operator mixing by controlling multiple Pro Tools systems from a single interface.
Discover Pro Tools | Satellite Link >
Photo illustration of Pro Tools | Satellite Link showing three Pro Tools software interfaces synced to timecode and controlled by a single workstation
Avid Premium Cloud Plans
Expand your storage space for Pro Tools Cloud Collaboration.
Discover Premium Cloud Plans >
Avid Premium Cloud Plans logo showing a line drawing of a cloud with an arrow pointing up
Avid Artist I/O
Capture, monitor, and output SD, HD, UHD, HDR, and surround content with unique video interfaces.
Discover Avid Artist I/O >
Collage of all four Avid Artist I/O hardware video interfaces, including Avid Artist | DNxIQ, DNxIV, DNxIP, and DNxID
AVID REWARDS
Get more value
Whether you’re a new or longtime Pro Tools user, get additional software and gifts from our valued partners (worth more than $1,000 USD)—it’s our way of saying thank you!
See what awaits >
AVID LINK
Connect anywhere on Avid Link
Find, connect, and collaborate with other music, audio, TV, film, and broadcast professionals around the world and expand your creative opportunities.
Smartphone and laptop with image of Avid Link free networking app next to purple logo
Learn more >
SPECIAL OFFER
Elevate and boost your sound
Get both the Aural Exciter and Big Bottom Pro in one incredible bundle for Pro Tools.
Laptop screen showing Aural Exciter and Big Bottom Pro plugin
Offer details >
GET STARTED FAST
TUTORIALS
Get going with Pro Tools, and learn tips and tricks to maximize your creative experience. 
Quickstart templates
Turn your ideas into songs quickly using templates
Build a session from scratch
Add tracks, virtual instruments, and more to a project
Writing and riffing
Record tracks and copy/paste audio to build up a song
Building it out
Record, edit, and loop drum and other MIDI parts
In the pocket
Perfect performances using Elastic Audio and more
Simplicity in mixing
Balance faders, add plugins, and more
Writing and riffing
Building it out
In the pocket
Introduction to Folder Track
Learn the basics of Folder Tracks in Pro Tools.
Folder Tracks for Audio Post Production
Learn tips and tricks for using Folder Tracks in audio post production.
Folder Tracks for Music Production
Learn tips and tricks for using Folder Tracks in music production.
Retrospective MIDI record
Capture ideas and improvisations post-performance
Track presets with playlists
Use track presets for playlists, templates, and media
Track comping for post
Get tips for comping ADR performances
Edit window scrolling
Change Edit window scrolling modes during playback
Navigation shortcuts
Get to where you want to go faster with shortcuts
Search plugins and busses
Use search within menus to speed up your workflow
Multiselect within menus
Select multiple items in menus, saving time
Relative grid
Get insight into the improved relative grid workflow
Relative grid
Using Boom (part 1)
Lay down beats with this virtual drum machine
Using Boom (part 2)
Program your own drum parts in Boom
MIDI Editor (part 1)
View and record instrument parts
MIDI Editor (part 2)
Edit virtual instrument and MIDI parts
Score your music
Write music with built-in notation tools
Comp tracks
Create perfect takes by comping together tracks
Work in playlist view
Record vocal and instrument performances easily
Intro to Elastic Time
Work with audio tracks in the same way as MIDI
Using Boom (part 1)
Using Boom (part 2)
Score your music
Comp tracks
POWER YOUR SOUND
GET PRO TOOLS
Pro Tools has an option for everyone, from students just starting out, to artists, musicians, producers, mixers, and audio post professionals.
Compare versions
Pro Tools | First
Pro Tools
Students and teachers
Get special pricing on Pro Tools, starting at $9.99/mo USD, with verified academic eligibility.
See your options >
Enterprise and institutions
Find out how to get Pro Tools for your production, business, or educational needs.
Contact us >
Already have Pro Tools?
Upgrade to the latest version and get access to new features, loyalty rewards, and more.
See your options >
Use of cookies on this site:
Cookies allow us to remember your sign-in details, to optimize site functionality and to deliver content tailored to your interests. We collect and use personal information, such as cookies, in accordance with our Privacy Policy. Click "Agree and proceed" to accept cookies and go to our site, or visit our Privacy Policy to learn more about cookies and how to manage or disable cookies. Please note that some Avid web pages, including the Avid Online Store, will not work if cookies are disabled.
Find out more
Agree and proceed
